Delete an Element from an Existing Reusable Configuration Module
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).- Expand the Configuration Manager slider, and select .
- Select the RCM, and click Load.
- Select the element you want to delete from the Elements defined table, and click Delete.
- In the confirmation dialog, click OK.
