Reusable Configuration Module Input Wizard Configuration Example
The following example shows how input values are entered in the RCM Input wizard screen for an SIP Trunk service RCM.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).
  1. Enter values for all specified attributes and click Next.
  2. Enter values for all specified attributes and click Next.
  3. Enter values for all specified attributes and click Apply.
    The configuration modifications are validated against the target device's data model schema.
