Delete a Reusable Configuration Module
An RCM is deleted only if it is not assigned to any device or configuration with a dependency. When the RCM is deleted, it is permanently removed from the database and cannot be retrieved.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).- Expand the Configuration Manager slider, and select .
- In the Reusable Configuration module table, select the RCM you want to delete, and click Delete.
- In the Delete confirmation dialog, click Yes.
