View Alarm Summary Data
- Expand the Dashboard Manager slider and select Summary view.
- In the Device column of the Managed Devices table, select the device you want to view. In the Alarm Summary table, a bar chart displays the alarm counts for all alarm categories for your device. You can mouse over a bar within the chart for the number of alarms that bar represents. See the Change the Default Severity Alarm Colors section in the Security Manager chapter for more information.
- Click Refresh to update alarm summary data.
- Click View Alarms to view alarm data in Fault Manager.
- Click Back to return to the main summary view display.
