Viewing KPI, Alarms, and License Data
- Expand the Dashboard Manager slider and select Summary view.
In the
Device column of the
Managed Devices table, select the device you want to view. In the
Key Performance Indicators table, the following information displays for your device:
Name Description Device The device managed by Oracle Communications Session Element Manager and for which the data is retrieved through an SNMP query. Location The physical location for this managed device. Up Time The system up time for this device in days, hours, minutes, and seconds. Health Score The health score for this device. The health score range is 0 to 100. Health scores lower than 60 indicate the device is in poor health. CPU The percentage of CPU used in this device. Memory The percentage of memory used in this device. Licensed Session Used The number of concurrent calls from the system performance report and current signaling sessions. - Click Refresh to update KPI data.
- Click View Alarms to view alarm data in Fault Manager.
- Click Back to return to the main summary view display.
