Fans Tab
| Name | Description |
| Index | A monotonic, increasing number. When this number reaches the maximum value, the agent wraps the value back to 1. |
| Location | Location of the fan. Values are:
| Description | The description of the fan. Values are:
| Current speed (% or range) | The current fan speed percentage. |
| Fan state | The current fan speed state. Values are:
| Slot ID | The slot in which this fan is found. |
