Temperature Tab
| Name | Description |
| Index | A monotonic, increasing number. When this number reaches the maximum value, the agent wraps the value back to 1. |
| Temperature source | The entity being monitored for temperature. |
| Description | A description of the temperature being monitored. |
| Current temperature (degrees Celsius) | The current temperature of the main board PROM in Celsius. |
| Sensor state | Current state of the temperature which can have one of the following values:
| Slot ID | The slot on which this temperature is found. |
| Slot type | The type of module found in this slot. |
