Voltage Tab
| Name | Description |
| Index | A monotonic, increasing integer. When it reaches the maximum value the agent wraps the value back to 1. |
| Voltage type | Value which indicates the sensor monitoring voltage. Values are:
| Description | The description of the entity being monitored for voltage. Values are:
| Current voltage (millivolts) | The current voltage measurement, in millivolts, if available. A value of -1 indicates that the monitor cannot obtain a value. |
| Sensor state | The current state of the voltage for the device being monitored. Values are:
| Slot ID | The slot on which this voltage is found. |
| Slot type | The type of module found in this slot. |
