Synchronize System Alarms with a Device
If the NF has an HA device pair, when you synchronize one device the other device in the pair is also synchronized.
- Expand the Device Manager slider and click Devices.
- In the Managed Devices pane, click the device you want to synchronize with system alarms and click .
- In the Synchronize alarms dialog box, click Yes.
- In the Information dialog box that displays, click OK.
