Manage a Device Configuration in a Network Function Device Cluster
When new device variables are added to an offline configuration (in Configuration Manager) that NF device cluster devices use, you must configure each device in a device cluster with its needed device parameters.
- Expand the Configuration Manager slider and click Devices.
- In the Managed Devices pane, navigate to an NF device cluster device and click Configure.
- In the Configure data variable for.... dialog box, enter the required parameter(s) for the data variables for which you are prompted.
- Click Finish.
