CPU Core Pane
| Name | Description |
| Core index | A monotonic, increasing integer for the sole purpose of indexing. |
| Description | The core ID and slot location. |
| CPU usage | The percentage of total CPU being used. |
| State | The current CPU state. |
| Memory descriptor | The type of RAM memory. |
| Memory usage | The current amount of RAM being used by the CPU. |
