Session Element Manager Traps
A list of SNMP traps (SNMP Trap OIDs) that originate from devices that appear in ESEM events and alarms.
- Expand the Fault Manager slider and select Trap event setting.
- In the
Select dialog box, select the
AcmeSD trap group row from the
Trap groups table and click
OK.
The following list describes some of the SNMP traps that are supported by the product plugin.
| Trap | Event Type | Description |
| apEnvMonl2CFailNotification | l2C | Indicates that the Inter-IC bus (I2C) state changed from normal (1) to not functioning (7). |
| apNNCReportingPswdExpiration | Reporting | Warns that the Oracle database (OCSREMDW) user password and the BI Publisher database user passwords (DEV_MDS, DEV_BIPLATFORM, NNCENTRAL) that you configured in the Report Manager installation expire after 180 days. This warning appears 7 days before these passwords expire by default. |
| apNNCReportingPswdExpirationClear | Reporting | Clears the Oracle and BIPublisher database user password expiration warnings. |
| apSysMgmtGroupTrap | apSysMgmt | Associates with the proprietary Oracle ap-smgmt.mib. This specific trap provides a way to gather a grouping and gathering of system status information for CPU, memory, license, health, and so on. |
| apSysMgmtGroup trap | ARP capacity | Measures the ARP capacity, which is the percentage of the ARP table in content addressable memory (CAM) utilization. |
| authenticationFailure | AuthTrap | The standard authenticationFailure trap is used when the SNMPv2 agent received a protocol message that was not properly authenticated. |
| apSysMgmtGroupTrap | CPU | Measures the percentage of CPU utilization. |
| apSysMgmtAlgdCPULoadTrap | CPU load | Measures the percentage of CPU of application tasks has exceeded the threshold algd-load-limit |
| apSysMgmtDOSTrap | DoS | Displays the Oracle Denial of Service (DoS) protection proprietary trap. |
| apSysMgmtGatewayUnreachable | Gateway | This alarm displays the status of gateway reachability. |
| apSysMgmtExpDOSTrap | Enhanced DoS | Indicates a device exceeded configured thresholds and was denied access. |
| apSysMgmtFanTrap | Fan | Indicates that the fan unit speed fell below the monitoring level. |
| apSysMgmtH323InitFail | H323 Stack | Describes the status of H.323 stack. |
| apSysMgmtPushServerUnreachableTrap | HDR | This alarm indicates that the specified server becomes unreachable by the system collector. |
| apSysMgmtGroupTrap | Health | Indicates the system health percentages. |
| apLicenseApproachingCapacityNotification | License | Associates with the proprietary Oracle ap-license.mib, which provides information about the status of your system licenses. |
| linkDown | Link | The SNMPv2 agent detects that the ifOperStatus object of an interface has transferred from the up state to the down state. The ifOperStatus value indicates the other state. |
| linkUp | Link | The SNMPv2 agent detects that the ifOperStatus object of an interface has transferred from the down state to the up state. The ifOperStatus value indicates the other state. |
| apSysMgmtMediaBandwidthTrap | Media bandwidth | This alarm indicates that bandwidth allocation failed at a percentage higher or equal to the system’s default threshold rate. |
| apSysMgmtMediaPortsTrap | Media ports | This alarm indicates that port allocation failed at a percentage higher or equal to the system’s default threshold rate. |
| apSysMgmtMediaUnknownRealm | Media realm | This alarm shows the status of the media realm. |
| apSysMgmtGroup | Memory | Displays the percentage of memory utilization. |
| apEnvMonStatusChangeNotification | Monitor | This alarm is associated with the proprietary Oracle ap-env-monitor.mib, which gathers information about fan speed, voltage, temperature, and power supply for the system. It also sends out traps when status changes occur. |
| apSysNATCapacity | NAT capacity | Shows the percentage of NAT table (in CAM) utilization. |
| apSysMgmtNTPClockSkewTrap | NTP Clock Skew | This alarm indicates NTP had to adjust the clock by more than 1000 seconds. |
| apSysMgmtNTPServerUnreachableTrap | NTP server | This alarm indicates that the specified NTP server is unreachable. |
| apSysMgmtNTPServiceDownTrap | NTP service | This alarm indicates that all configured NTP servers are unreachable. |
| apEnvMonStatusChangeNotification | Power | This alarm indicates the status of power supply. |
| apSysMgmtRealmMinutesExceedClearTrap | Realm Minutes Exceeded | This alarm describes the monthly minutes exceeded for a realm. |
| apSysMgmtRadiusDownTrap | RADIUS Servers | This alarm shows the status of the RADIUS server. |
| coldStart | Reboot | This alarm shows the proprietary version of the standard coldStart trap. |
| apSysMgmtRedundancyTrap | Redundancy | This alarm indicates that a state change occurred on either the primary or secondary system in a redundant (HA) pair. |
| apSysMgmtCfgSaveFailTrap | Save-config | Indicates that an error occurred while the system was trying to save the configuration to memory. |
| apSysMgmtStatusChange | Session agent | This alarm displays the session agent information, which includes the hostname, IP address, status, and the reason for the status. |
| apSysMgmtSingleUnitRedundancyTrap | Single unit redundancy | This alarm shows if the status of a slot changed. The varbinds contain the new information for the slot. |
| apSysMgmtSurrogateRegFailed | Surrogate registration | This alarm shows the status of surrogate registration and associated with the trap. |
| apSysMgmtTaskSuspendTrap | Task | This alarm indicates that there is a suspended task. |
| apSysMgmtTempTrap | Temperature change | Indicates the system temperature. |
| ColdStart | ColdStart | The SNMPv2 agent is reinitializing itself and its configuration may have been altered. |
