Track Device Configuration Changes
Use this task to track changes that are made to device parameters.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).- Expand the Configuration Manager slider, and click the Devices folder.
- In the Managed Devices table, expand the folder hierarchy, select a network function (NF) device, and click Get Inventory.
- In the Configuration inventory dialog that appears for the device, review the number of each type of configuration element.
- (Optional) Click Save to file.
- In the dialog that appears, click OK to download the information in the format of a comma-separated values (CSV) file to your system.
