View Device Tasks
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC) and the Enterprise Communications Broker (ECB).- Expand the Configuration Manager slider, and click the Devices folder.
- In the Managed Devices table, expand the folder hierarchy, select a network function (NF) device, and click View tasks.
- In the Device tasks table, you can view the device operations that are performed and if you select a device operation row, you can see logs for this device operation by clicking View Log.
