Diameter Director Agent
The following table lists the SOAP attributes and sub-elements for the DIAMETER Director agent.
| SOAP Attributes/Sub-elements | ACLI
session-router->diameter-director-agent |
Default Values | Valid Values | SBC Version |
| port
constraintName appProtocol watchDogTimer state transportProtocol responseMap hostname inManipulationId realmId outManipulationId connectionMode description options ipAddress diamDirApplication appId vendorId appType |
port
constraint-name protocol watchdog-timer state transport-protocol response-map hostname in-manip-ip realm-id out-manip-id connection-mode description options ipAddress diameter-director-applications application-id vendor-id application-type |
3868
30 enabled TCP outbound 0 authentication |
Valid port number
0-65535 enabled or disabled TCP or SCTP FQDN or IP address diameter-manipulation rule Existing realm name diameter-manipulation rule outbound, inbound, inbound-dynamic-ip 256-character string IP address 32-bit hexadecimal or 32-bit integer 32-bit integer authentication or accounting |
DD1.0.0 and above |
| tosValue | tos-value | DD1.0.0M1 and DD2.0.0M1 |
