Diameter Director Configuration
The following table lists the SOAP attributes and sub-elements for the DIAMETER Director agent.
| SOAP Attributes/Sub-elements | ACLI
session-router->diameter-director-config |
Default Values | Valid Values | SBC Version |
| redundancyPort
llAction dynamicRouting state loadLimit activeRedPort redNumTrans llExpResultCode statefulPolicy llResultCode |
redndancy-port
load-limit-action dynamic-routing state load-limit active-redundancy-port red-max-transactions load-limit-exp-result-code stateful-policy load-limit-result-code |
1999
reject enabled enabled 85 9000 50000 3004 |
Valid port number
reject or drop enabled or disabled enabled or disabled 0-100 Valid port number 0-999999 Valid result code |
DD1.0.0 and above |
| options | options | DD2.0.0 and above |
