Diameter Director Constraints
The following table lists the SOAP attributes and sub-elements for the DIAMETER Director constraints.
| SOAP Attributes/Sub-elements | ACLI
session-router->diameter-director-constraints |
Default Values | Valid Values | SBC Version |
| burstWindow
maxInbSustainedRAte maxOutbBurstRate sustainedRate useConstraints maxBurstRate maxInbBurstRate maxOutbBurstRate timeToResume name maxSustainedRate lastModifiedBy resultCode lastModifiedDate messageRateConstraints maxOutSustainedRate maxInSustainedRate maxInBurstRate command maxOutBurstRate |
burst-rate-window
max-inbound-sustain-rate max-outbound-burst-rate sustain-rate-window state max-burst-rate max-inbound-burst-rate max-outbound-burst-rate time-to-resume name max-sustained-rate last-modified-by result-code last-modified-date message-rate-constraints max-outbound-sustain-rate max-inbound-sustain-rate max-inbound-burst-rate command max-outbound-burst-rate |
0
0 0 0 enabled 0 0 0 0 0 3004 0 0 0 0 |
0-999999
0-999999 0-999999 0-999999 enabled or disabled 0-999999 0-999999 0-999999 0-999999 0-999999 1000-6000 0-999999 0-999999 0-999999 0-999999 |
DD1.0.0 and above |
