Diameter Director Group
The following table lists the SOAP attributes and sub-elements for the DIAMETER Director group.
| SOAP Attributes/Sub-elements | ACLI
session-router->diameter-director-constraints |
Default Values | Valid Values | SBC Version |
| groupName
description lastModifiedBy state lastModifiedDate strategy inManipulationId outManipulationId recursiveRouting recursionTimeout doRecursion transactionTimeout resultCodes expResultCodes diamDirApplication appId vendorId appType destination seqno name |
group-name
description last-modified-by state last-modified-date strategy in-manip-id out-manip-id recursive-routing recursion-timeout do-recursion transaction-timeout result-codes exp-result-codes diameter-director-application application-id vendor-id application-type destinations seqno name |
enabled
hunt 100000 disabled 32000 0 authentication |
256 character string
enabled or disabled hunt diameter-manipulation rule diameter-manipulation rule 1-999999 enabled or disabled 1-999999 valid diameter result code 32-bit hexadecimal or 32-bit integer 32-bit integer authentication or accounting |
DD1.0.0 and above |
