Diameter Director Interface
The following table lists the SOAP attributes and sub-elements for the DIAMETER Director interface.
| SOAP Attributes/Sub-elements | ACLI
session-router->diameter-director-constraints |
Default Values | Valid Values | SBC Version |
| constraintName
outManipId state routingPolicy realmId suppVendorIds originHostId description originHostFormat lastModifiedBy lastModifiedDate inManipId sipPort port tlsProfile transProtocol address anonMode imsAkaProfile sctpMultiHomeAddrs diamDirApplication appId vendorId appType |
constraint-name
out-manip-id state routing-policy realm-id supported-vendor-ids origin-host-identifier description origin-host-format last-modified-by last-modified-date in-manip-id diameter-director-ports port tls-profile transport-protocol address allow-anonymous ims-aka-profile multi-home-addrs diameter-director-application application-id vendor-id application-type |
enabled
none 3868 TCP all 0 authentication |
diameter director constraint
diameter-manipulation rule disabled 256 character string 256 character string 256 character string none, identifier, identifier-with-realm diameter-manipulation rule number greater than 1023 TCP, SCTP IP address all, agents-only IP address 32-bit hexadecimal or integer 32-bit integer authentication, accounting |
DD1.0.0 and above |
| tosValue | tos-value | DD1.0.0M1 and DD2.0.0M1 |
