Diameter Manipulation
The following table lists the SOAP attributes and sub-elements for the DIAMETER manipulation.
| SOAP Attributes/Sub-elements | ACLI
session-router->diameter-director-constraints |
Default Values | Valid Values | SBC Version |
| description
name lastModifiedBy lastModifiedDate diameterManipRules seqno newValue avpCodeDescr name cmpType action matchValue avpCode msgType msgCmdCode avpType avpHeaderRule headerType newValue name action matchValue |
description
name last-modified-by last-modified-date diameter-manip-rules seqno new-value descr-avp-code name comparison-type action match-value avp-code msg-type msg-cmd-code avp-type avp-header-rule header-type new-value name action match-value |
case-sensitive
none 0 any 0 none none |
256 character string
256 character string AVP header-rule 256 character string case-sensitive, canse-insensitive, pattern-rule, boolean none, add, delete, store, diameter-manip, group-manip, find-replace-all, replace AVP code any, request, reply diameter message code none, octet-string, octet-hex, integer32, unsignedint32, address, diameteruri, enumerated avp-flag or avp-vendor-id none, add, delete, replace |
DD1.0.0 and above |
