Realm
The following table lists SOAP attributes and sub-elements for the realm.
| SOAP Attributes/Sub-elements | ACLI
media-manager->realm-config |
Default Values | Valid Values | SBC Version |
| id *#
addrPrefix parent acliObjectName *# subPortId *# maxBandwidth mrInRealm mrInNetwork isMSMRelease qosEnable mediaPolicy intranslationid outtranslationid dnsRealm classProfile trustLevel rateLimit errMsgThreshold maxMsgThreshold denyTimer |
identifier
addr-prefix parent-realm max-bandwidth mm-in-realm mm-in-network msm-release qos-enable media-policy in-translationid outtranslationId dns-realm class-profile access-control-trust-level average-rate-limit invalid-signal-threshold maximum-signal-threshold deny-period |
0.0.0.0
0 disabled enabled disabled disabled none 0 0 0 30 |
24 characters
0.0.0.0 or ipv4 or ipv4/mask empty or <realm> 0-999999999 enabled/disabled enabled/disabled enabled/disabled enabled/disabled empty or <QoS marking profile> empty or <trans-profile> empty or <realm> empty or <cls-profile> none, low, medium, high 0-999999999 0-999999999 0-999999999 0-999999999 |
4.0.0 and above |
| RealmNetworkInterfaceId | network-interfaces | <phy:port-id> <ip_version> or lo0:0:4 | Before 6.4.0 | |
| RealmNetworkInterfaceId | network-interfaces | <phy:port-id>, <ip_version>, lo0:0:4, or lo0:0:6 | 6.4.0 or later | |
| symmetricLatching | symmetric-latching | disabled | enabled/disabled | |
| paiStrip | pai-strip | disabled | enabled/disabled | |
| trunkContext
bwManager inManipulationId outManipilationId options maxMsgThresholdUntrusted |
trunk-context
ext-policy-svr in-manipulationid out-manipulationid options untrusted-signal-threshold |
0 | empty or <pol-server>
empty or <sip-manipulation> list of options separated by comma 0-999999999 |
| mmInSystem
restrictedLatching restrictionMask |
mm-in-system
restricted-latching restriction-mask |
enabled
none 32 |
enabled/disabled
none, sdp, peer-ip 1-32 |
4.0.1 and above |
| mmSameIp
earlyMediaAllow RealmAdditionalPrefixes prefix *# |
mm-same-ip
early-media-allow additional-prefixes |
enabled | enabled/disabled
empty, none, reverse, or both list of ipv4/mask ipv4/mask |
| acctEnable | accounting-enable | enabled | enabled, disabled | 4.1.0 and above |
| netMgmtCtrl userCacMode
userCacBandwidth userCacSessions delayedMediaUpdate nonMmBwCAC codecPolicy codePolicyInRealm |
net-management-control
user-cac-mode user-cac-bandwidth user-cac-sessions delay-media-update bw-cac-non-mm codec-policy codec-manio-in-realm |
disabled
none 0 0 disabled disabled disabled |
enabled or disabled
none, aor, ip 0-999999999 0-999999999 enabled/disabled enabled/disabled empty or <codec-policy> enabled/disabled |
4.1.1 and above |
| generateUDPCksum
enforcementProfile |
generate-udp-checksum
enforcement-profile |
disabled | emoty or disabled
empty or <enforcement-profile> |
4.1.4; 5.1.0 and above |
| monthlyMinutes
constraintName |
monthly-minutes
constraint-name |
0 | 0-71582788
empty or <session-constraint> |
4.1.4 and 5.1.1 |
| referCallTransfer
description |
refer-call-transfer
description |
disabled | enabled, disabled | 5.1.1 and above |
| callRecordingServerId | call-recording-server-id | empty, defined call recording server | 6.0.0 and above | |
| hmrString
maxPriorityBandwidth fallbackBandwidth icmpDetectMultip icmpAdvInterval icmpTargetIp MatchMediaProfile acliObjectName *# natTrustThreshold stunEnable stunServerIp stunServerPort stunChangedIp stunChangedPort qosConstraintName |
manipulation-string
max-priority-bandwidth fallback-bandwidth icmp-detect-multiplier icmp-advertisement-interval icmp-target-ip match-media-profiles nat-trust-threshold stun-enable stun-server-ip stun-server-port stun-changed-ip stun-changed-port qos-constraint |
0
0 0 0 0 disabled 0.0.0.0 3478 0.0.0.0 3479 |
0-999999999
0-999999999 0-999999999 0-999999999 ipv4 list of <media-profile>, <media-profile>::, <media-profile>::<subname>, *, *::, *::<subname> 0-65535 enabled, disabled ipv4 1025-65535 ipv4 1025-65535 empty or <qos constraint> |
6.1.0 and above |
| sipProfile
sipIsupProfile referCallTransfer dynReferTerm cacFailThreshold untrustedCacFailThreshold manipPattern |
sip-profile
sip-isup-profile refer-call-transfer dyn-refer-term cac-failure-threshold untrust-cac-failure-threshold manipulation-pattern |
disabled
disabled 0 0 |
empty or <sip-profile>
empty or <sip-isup-profile> disabled, enabled, dynamic enabled, disabled 0-999999999 0-999999999 |
6.2.0 and above |
| mediaSecPolicy
addrPrefix xnqState hairpinId |
media-sec-policy
addr-prefix xnq-state hairpin-id |
xnq-unknown | empty or <media-sec-policy>
ipv4 or ipv4/mask, ipv6, ipv6/mask xnq-unknown, xnq-potential, xnq-remove 0-65535 |
CX6.2.0 and above |
