Network Interface
The following table lists SOAP attributes and sub-elements for the network interface.
| SOAP Attributes/Sub-elements | ACLI system->network-interface |
Default Values | Valid Values | SBC Version |
| acliObjectName * subPortId *# hostname ipAddress utilityAddress secondUtilityAddress netmask gateway gatewaySec NetworkInterfaceGWHeartbeat state # timeout retrycount retryTimeout healthDec domNameServer domNameServerB1 domNameServerB2 defDomainName HipIpList ip *# protocolParameters ftpAddress icmpAddress snmpAddress telnetAddress |
name sub-port-id hostname ip-address pri-utility-addr sec-utility-addr netmask gateway sec-gateway gw-heartbeat state heartbeat retry-count retry-timeout health-score dns-ip-primary dns-ip-backup1 dns-ip-backup2 dns-domain hip-ip-list ftp-address icmp-address snmp-address telnet-address |
<phy> disabled 0 0 1 0 |
<phy> 0-4095 0-255 chars Ipv4 Ipv4 Ipv4 lpv4 Ipv4 Ipv4 enabled/disabled 0-65535 0-65535 1-65535 0-100 Ipv4 Ipv4 Ipv4 list of IPs ipv4 empty or combo of (ftp, icmp, snmp, telnet) ftp HIP icmp HIP snmp HIP telnet HIP |
4.0.0 and above |
| dnsTimeout | dns-timeout | 11 | 0-4294967295 | |
| description | description | 255 chars | 5.0.0 and above | |
| IcmpipList ip *# |
icmp-address | HIP | 4.1.4; 5.1.0 and above | |
| hostname ipAddress utilityAddress secondUtilityAddress netmask gateway gatewaySec domNameServer domNameServerB1 domNameServerB2 HipIpList ip *# protocolParameters IcmpIpList ip *# |
hostname ip-address pri-utility-addr sec-utility-addr netmask gateway sec-gateway dns-ip-primary dns-ip-backup1 dns-ip-backup2 hip-ip-list icmp-address |
0-255 chars, ipv4, ipv6 Ipv4, ipv6, ipv6/prefix Ipv4, ipv6 Ipv4, ipv6 Ipv4, not allowed for ipv6 Ipv4, ipv6 Ipv4, ipv6 Ipv4, ipv6 Ipv4, ipv6 Ipv4, ipv6 list of IPs ipv4, ipv6 empty or combo of (ftp, icmp, snmp, telnet) list of ipv4, ipv6 |
CX6.2.0 and above |
