SIP Interface
The following table lists SOAP attributes and sub-elements for the SIP interface.
| SOAP Attributes/Sub-elements | ACLI session-router->sip-interface |
Default Values | Valid Values | SBC Version |
| state RealmID * trustMode SIPConfigurationSIPPort address *# port *# transProtocol *# anonMode proxyMode redirectAct contactSip telUri fqdnDomain natTraversal natInterval regMinExpire regInterval registrationCaching isRouteReg SIPConfigurationCarriers acliObjectName *# options |
state realm-id trust-mode sip-port address port transport-protocol allow-anonymous proxy-mode redirect-action contact-mode teluri-scheme uri-fqdn-domain nat-traversal nat-interval min-reg-expire registration-interval registration-caching route-to-registrar carriers options |
enabled <realm> all 5060 UDP all none disabled none 30 300 3600 disabled disabled |
enabled/disabled <realm> all, agents-only, relam-prefix, registered ipv4 1025-65535 UDP or TCP all, agents-only, realm-prefix, registered, register-prefix empty, proxy, redirect, record-route, stateless empty, proxy, recurse none, maddr, strict, loose enabled, disabled none, always, rport 0-999999999 1-999999999 0-999999999 enabled/disabled enabled/disabled list of carriers list of options seperated by comma |
4.0.0 and above |
| natmaxInterval natIntervalIncrement natTestIncrement sipdynamicHnt |
max-nat-interval nat-int-increment nat-test-increment sip-dynamic-hnt |
3600 10 30 disabled |
enabled, disabled | |
| stopRecurse | stop-recurse | 401,407 | list of response codes, 300-599 seperated by comma | |
| portMapStart portMapEnd |
port-map-start port-map-end |
0 0 |
0, 1025-65535 0, 1025-65535, end>start |
| trustMode extPolicyServer defaultLocationString imsFeature NetworkID anonymousPriority termTgrpMode chargingVectorMode chargingFuncAddrMode ecfAddress ccfAddress operatorIdentifier inManipulationId outManipulationId |
trust-mode ext-policy-server default-location-string sip-ims-feature network-id anonymous-priority term-tgrp-mode charging-vector-mode charging-function-address-mode ecf-address ccf-address operator-identifier in-manipulationid out-manipulationid |
disabled None None pass pass |
all, agents-only, relam-prefix, registered, none empty or <pol-server> enable/disabled NONE (4.0.1), none (4.2), normal, non-urgent, urgent, emergency none, iptel, egress-uri none, pass, delete, insert none, pass, delete, insert Ipv4 or hostname Ipv4 or hostname empty or <sip-manipulation> |
| implicitServiceRoute | implicit-service-route | disabled | strict, enabled, disabled | 4.0.1 and above |
| tcpNatInterval isSecure rfc2833-mode rfc2833-payload maxConnPerPeer maxConn idleConnTimeout SIPConfigurationSIPPort transProtocol tlsProfile |
tcp-nat-interval secured-network rfc2833-mode rfc2833-payload per-src-ip-max-incoming-conns max-incoming-conns inactive-conn-timeout sip-port transport-protocol tls-profile |
90 disabled transparent 101 0 0 0 |
0-99999999 enabled, disabled transparent, preferred 96-127 0-20000 0-20000 0-999999999 UDP, TCP, TLS <tls-profile> if TLS specified |
4.1.0 and above |
| constraintName implicitServiceRoute |
constraint-name implicit-service-route |
disabled | empty or <session-constraint> strtict, enabled, disabled |
4.0.1; 4.1.1 and above |
| responseMap localresponseMap |
response-map local-response-map |
empty or <sip-response-map> | 4.1.1 and above | |
| trans-expire invite-expire max-redirect-contacts rfc2833-mode |
0-999999999 0-999999999 0-10 transparent, preferred, dual |
| untrustedConnTimeout | untrusted-conn-timeout | 0 | 0-999999999 | 5.0.0 and above |
| tcp-keepalive chargingFuncAddrMode enforcementProfile |
tcp-keepalive charging-function-address-mode enforcementProfile |
none pass |
none, disabled, enabled none, pass, delete, insert, delete-and-respond, insert-reg-cache empty or <enforcement profile> |
4.1.4; 5.1.0 and above |
| add-sdp-invite SIPInterfaceMediaProfile |
add-sdp-invite add-sdp-profile |
disabled | disabled, invite, reinvite list of media profiles |
4.1.4; 5.1.1 and above |
| referCallTransfer routeUnauthorizedCalls description |
refer-call-transfer route-unauthorized-calls description |
disabled | enabled, disabled empty, defined SA or SAG |
5.1.1 and above |
| implicitServiceRoute | implicit-service-route | disabled | strict, enabled, disabled, absent, replace | 6.0.0 and above |
| chargingVectorMode | charging-vector-mode | pass | none, pass, delete, insert, delete-and-respond | 6.0.0M1 and above |
| imsAkaFeature imsAkaProfile hmrString SIPConfigurationSIPPort transProtocol |
ims-aka-feature ims-aka-profile manipulation-string sip-port transport-protocol |
disabled UDP |
enabled, disabled <ims-aka-profile> or empty UDP, TCP, TLS, SCTP |
6.1.0 and above |
| sipProfile sipIsupProfile manipPattern |
sip-profile sip-isup-profile manipulation-pattern |
empty or <sip-profile> empty or <sip-isup-profile> |
6.2.0 and above | |
| SIPConfigurationSIPPort address *# |
sip-port address |
ipv4, ipv6 | CX6.2.0 and above |
