SIP NAT
The following table lists SOAP attributes and sub-elements for the SIP NAT.
| SOAP Attributes/Sub-elements | ACLI
Session-router->sip-nat |
Default Values | Valid Values | SBC Version |
| RealmID *
ProxyAddress ProxyPort ExternalAddress HomeAddress HomeProxyAddress HomeProxyPort RouteHomeProxy prefix TunnelRedirect UserNATTag HostNATTag DomainSuffix ParamMode ParamName SipNatHeaders acliObjectName*# |
realm-id
ext-proxy-address ext-proxy-port ext-address home-address home-proxy-address home-proxy-port route-home-proxy address-prefix tunnel-redirect user-nat-tag host-nat-tag domain-suffix use-url-parameter parameter-name headers |
<realm>
5060 0 disabled disabled -acme- ACME- none list of nat headers: Call-ID Contact f From I Join m rRecord-Route Refer-To Replaces Replay-To Route t To v Via |
<realm>
<0.0.0.0> or ipv4 1025-65535 Ipv4 Ipv4 Ipv4 1025-65535 enabled, disabled, forced empty, *, 0.0.0.0, ipv4/bitmask enabled/disabled <.com> none, from-to, all list of nat headers: Call-ID Contact f From I Join m r Record-Route Refer-To Replaces Replay-To Route t To v Via with values = NAT, fqdn-ip-ext, fqdn-ip-tgt, ip-ip-ext, ip-ip-tgt |
4.0.0 and above |
