H.323 Stack
The following table lists SOAP attributes and sub-elements for the H.323 stack.
| SOAP Attributes/Sub-elements | ACLI
Session-router->h323->h323-stack |
Default Values | Valid Values | SBC Version |
| acliObjectName *#
state realm-id * assoc-stack local-ip ras-port q931-port H323AlternateTransport ipAddress *# q931-max-calls max-calls max-channels q931-start-port q931-number-ports dynamic-start-port dynamic-number-ports tcp-keeplive isgateway AnonMode filename H323TerminalAial e164 *# url *# ipAddress *# email *# h323-ID *# H323Prefixes e164 *# url *# ipAddress *# email *# h323-ID *# |
name
state realm-id assoc-stack local-ip ras-port q931-port alternate-transport q931-max-calls max-calls max-channels q931-start-port q931-number-ports dynamic-start-port dynamic-number-ports tcp-keepalive isgateway allow-anonymous filename terminal-alias prefixes |
enabled
<realm> 0.0.0.0 1719 1720 200 200 6 0 0 0 0 disabled enabled all |
24 characters
enabled/disabled <realm> empty or <h323-stack> empty or <HIP> 1025-65535 1025-65535 list of <ipv4:port> Ipv4:port >0 >0, must > q931-max-calls >0 0-65535 0, 1024, 2048, 4096, 8192, 16384, 32768 0-65535 0, 1024, 2048, 4096, 8192, 16384, 32768 enabled/disabled enabled/disabled all, agents-only, realm-prefix list of e164, url, h323-ID, email, ipAddress list of e164, url, h323-ID, email, ipAddress for gateway only |
4.0.0 and above |
| registration-ttl
processRegistration proxy-mode h245-stage h245-tunneling stack-options auto-gk-discovery multicast gatekeeper gk-identifier callStartFast callStartSlow H323MediaProfile acliObjectName *# fs-in-first-msg |
registration-ttl
process-registration proxy-mode h245-stage h245-tunneling options auto-gk-discovery multicast gatekeeper gk-identifier call-start-fast call-start-slow media-profiles fs-in-first-msg |
120
disabled connect disabled disabled enabled disabled disabled |
>0 for gateway only
enabled/disabled for gatekeeper only NONE, H225, H245 CONNECT, SETUP, ALERTING, CALL PROCEEDING, DYNAMIC, FACILITY, SETUP or CONNECT, NONE enabled/disabled list of options seperated by comma enabled, disabled ipAddress=ipv4:port for gateway only ipAddress=ipv4:port enabled/disabled enabled/disabled, each time only fast or only slow enabled list of media-profiles enabled/disabled |
| rfc2833-mode | rfc2833-mode | transparent | transparent, preferred | 4.1.0 and above |
| description | description | 5.1.1 and above | ||
| H323StackAlarmThreshold
severity*# value |
alarm-threshold
severity value |
minor
0 |
minor, major, critical
0-100 |
6.2.0 and above |
