MGCP Config
The following table lists SOAP attributes and sub-elements for the MGCP config.
| SOAP Attributes/Sub-elements | ACLI
Session-router->mgcp-config |
Default Values | Valid Values | SBC Version |
| realmPrivate *
addressPrivate *# portPrivate mode divisor unitPrefix dnsAuthentication dnsTranslation natTraversal auditInterval options caRedundancy caPingMethod caPingInterval hostGWPublic addrGWPublic portGWPublic portGWPublic2realmPublic pubCAHost addrCAPublic portCAPublic |
pivate-realm
private-address private-port mode divisor unit-prefix dns-authentication dns-translation nat-traversal audit-interval options ca-redundancy ca-ping-method ca-ping-interval public-gw-host public-gw-address public-gw-port second-public-gw-portpublic-realm public-ca-host public-ca-address public-ca-port |
<realm>
2727 LineUnit 256 disabled disabled 0 disabled 0 0.0.0.0 2427 0<realm> 0.0.0.0 2727 |
<realm>
Ipv4 1025-65535 Host, LineUnit, LinePrefix, FQDN, FQDN2, OnlyHost 256, 65536, 16777216, 4294967295enabled/disabled empty or <trans-pfl> enabled/disabled list of options enabled/disabled NTFY 1 ping@host Ipv4/mask 1025-65535 0, 1025-65535<realm> Ipv4 1025-65535 |
4.0.0 and above |
| portALG | alg-port | 2427 | 1025-65535 | 4.1.4; 5.1.1 and below |
| MGCPConfigIpAddresses
Addr *# |
ca-failover-ip-addresses | List of ipv4
Ipv4 |
4.0.1 and above | |
| rsipFailures | rsip-failures | 500-509
511-519 522-599 |
500-599 | 5.1.0 and above |
| portMapStart
portMapEnd |
port-map-start
port-map-end |
0
0 |
0 or 1025-65535
0 or 1025-65535 |
5.1.1 |
| caPingRetries | ca-ping-retries | 0 | 0-4294967295 | SC6.1.0M1 |
