Removing an Associated Device
- Expand the Configuration Manager slider, and click Devices.
- In the Managed Devices table, click Add devices.
- In the Devices associated with Element Management pane, expand the folder hierarchy in the Targeted devices table, and click the network function (NF) device you want to remove.
Click
Remove.
Your device is no longer associated with Oracle Communications Session Element Manager and appears in the Device list pane.
- Click OK to apply the changes.
