Export Detailed Device Information from Configuration Manager
You can export network function (NF) device information to your local system, which allows data to be saved in a table-structured format for auditing or management purposes.
- Expand the Configuration Manager slider, and click Devices.
- In the Managed Devices pane, expand the folder hierarchy, select an NF device, and click View Changes.
- In the Configuration changes pane, click Save to File.
- In the dialog, click OK to download the information in the format of a comma-separated values (CSV) file to your system.
