Accessing License Details
Many components of the Oracle Communications session delivery product device software are licensed by Oracle and some product devices require a license key. Products using the newer license entitlements feature do not have entries in this area.
  1. Expand the Device Manager slider and click Devices.
  2. In the Managed Devices pane, click to select the device for which you want to show details and click Get Information > Show details.
  3. In the Device details pane, click the License tab. The following field and table columns display:
    Name Description
    License Key column The license number.
    Capacity column The maximum number of simultaneous sessions allowed by the device for all combined protocols.
    Install Date column The installation time and date when the software was installed on the device.
    N/A appears if a license is not enabled.
    Begin Date column The beginning time and date when the software was licensed on the device.
    Expire Date column The end time and date when the software license expired on the device.
    Protocol Names column All protocols licensed for this device. Values are: SIP, MGCP, and H.323.
    Feature Names column The following features can be licensed for this device:
    • Interworking (IWF)
    • Quality of Service (QoS)
    • Acme Control Protocol (ACP)
    • Local Policy (LP)
    • Session Agent Group (SAG)
    • ACC—Enables Oracle Communications session delivery product devices to create connections, and send CDRs to one or more RADIUS servers).
    • High Availability (HA)
    Object ID (Hidden) The database object ID for this device.
