PreviousNextJavaScript must be enabled to correctly display this content
Export Device Information from Device Manager
You can export network function (NF) device information to your local system (PC, server, and so on) in the format of a comma-separated values (CSV) file which allows data to be saved in a table-structured format for auditing or management purposes.
Expand the
Device Manager slider and click
Devices.
In the
Managed Devices pane, select the NF and click
Save to file.
In the dialog box that appears, click
OK to download the information in the form of a CSV file to your system.
The information in the CSV file that is saved to your system corresponds to the NF information displayed in the
Managed Devices pane.
