Add an Offline Configuration by Copying a Template
Use this task to copy an existing offline configuration or a pre-packaged offline configuration template to make a new offline configuration for your domain.
  1. Expand the Configuration Manager slider, and select Configuration tools > Offline configurations.
  2. In the Offline Config tab, select an offline configuration template from the table, and click Copy.
  3. In the Copy Offline Configuration dialog, enter the name of the new offline configuration.
  4. In the Success dialog, click OK.
    The new offline configuration appears in the table.
Load the new offline configuration and modify any of the pre-populated base parameters, as needed for your domain.
