Add an Offline Configuration from a Software Version
You can seed a configuration from a supported software version schema.
- On the Configuration Manager slider, choose Configuration tools > Offline configurations.
- In the Offline Config tab, click Add.
In the
Add offline configuration pane, complete the following fields:
Name Description Configuration name field The unique configuration name that is an alphanumeric value from 1 to 24 characters with no spaces and no special characters with the exception of the hyphen (-) and underscore (_). Note:
When you choose a name for a new global parameter configuration, this name must not start with the prefix "ID".A validation error (invalid oc name) occurs if the above rules are not followed.
Description field The description for the configuration. Offline configuration seeded from drop-down list Select Software version to create an offline configuration from a supported software version schema. Category Click the ellipsis (...) button to select the plug-in product vendor category. For example, SD (for Session Delivery products).
Component The default NF component delivered by the plug-in product vendor category.
Platform drop-down list Select the device hardware version to seed the configuration from a device template. Supported software version drop-down list Select the device software version in order to seed the configuration from a device template. - Click Apply.
- In the Success dialog, click OK.
Load the new offline configuration and modify any of the pre-populated base parameters, as needed for your domain.
