Create an Offline Configuration from a Managed Device
You can seed a configuration from a from an existing managed device configuration.
  1. On the Configuration Manager slider, choose Configuration tools > Offline configurations.
  2. In the Offline Config tab, click Add.
  3. In the Add offline configuration pane, complete the following fields:
    Name Description
    Configuration name field The unique configuration name that is an alphanumeric value from 1 to 24 characters with no spaces and no special characters with the exception of the hyphen (-) and underscore (_).
    When you choose a name for a new global parameter configuration, this name must not start with the prefix "ID".
    A validation error (invalid oc name) occurs if the above rules are not followed.
    Description field The description for the configuration.
    Offline configuration seeded from drop-down list Select Managed Device to create an offline configuration by copying an existing managed device configuration.
    Selected managed device field Click the ellipsis (...) button to launch the Select managed device dialog to navigate to a device associated with SEM, and click OK. This field populates with the IP address of the device.
  4. Click Apply.
  5. In the Success dialog, click OK.
Load the new offline configuration and modify any of the pre-populated base parameters, as needed for your domain.
