Extended Interface Stats Tab
| Name | Description |
| Name | The text string containing the name of the interface. The name is the one assigned by the local device. It could be a text name or a port number, depending on the interface naming syntax of the device. |
In
| Multicast packets | The number of packets delivered from this layer to a higher layer that were addressed to a multicast address. For a MAC layer protocol, it includes both group and functional addresses. |
| Broadcast packets | The number of packets delivered by this layer to a higher level that were addressed to a broadcast address. |
Out
| Multicast packets | The number of packets that higher-level protocols requested be transmitted that were addressed to a multicast address at this layer, including those discarded or not sent. |
| Broadcast packets | The number of packets higher-level protocols requested to be transmitted that were addressed to a broadcast address at this layer, including those discarded or not sent. |
HC In
| Octets | The total number of octets received on the interface, including framing characters. |
| Unicast packets | The number of packets delivered by this layer to a higher layer that were not addressed to a multicast or broadcast address at this layer. |
| Multicast packets | The number of packets delivered by this layer to a higher layer that were addressed to a multicast address at this layer. For a MAC layer protocol, this includes both group and functional addresses. |
| Broadcast packets | The number of packets delivered by this layer to a higher layer that were addressed to a broadcast address at this layer. |
HC Out
| Octets | Total number of octets transmitted out of the interface, including framing characters. |
| Unicast packets | Total number of packets that higher-level protocols requested be transmitted that were not addressed to a multicast or broadcast address at this layer; including those discarded or not sent. |
| Multicast packets | The total number of packets that higher-level protocols requested be transmitted that were addressed to a multicast address at this layer, including those discarded or not sent. For a MAC layer protocol, this includes both the group and functional addresses. |
| Broadcast packets | The total number of packets that higher-level protocols requested be transmitted that were addressed to a broadcast address at this layer; including those discarded or not sent. |
| Link up/down trap enable | This field indicates whether linkUp/linkDown traps should be generated for this interface. The value should be enabled(1) for interfaces that do no operate on top of any other interface and disabled(2) otherwise. |
| High Speed | The estimate of the interface’s current bandwidth in units of 1,000,000 bits per second. If a value of n is reported, the speed of the interface is in the range of n-500,00 to n+499,999. For interfaces that do no vary in bandwidth or for those where no accurate estimation can be made, a nominal bandwidth is given. |
| Connector Present | If the interface layer has a physical connector, the value is true(1). Otherwise it is false(2). |
