Interface Stats Utilization Tab
Name Description
Name The text string containing the name of the media interface. The name is the one assigned by the local device that can be a text name or a port number, depending on the interface naming syntax of the device.
Rx Utilization The receive media ports that are used for media ports indexed by IF index.
Tx Utilization The transmit media ports that are used for media ports indexed by IF index.
