Refresh a Performance Group
- Expand the Performance Manager slider and select Devices.
- In the Devices pane, navigate to the device group folder you want.
Select a device in the device group folder and click
View.
The Performance Groups folder appears in the navigation pane with performance groups below it.
- Under the Performance Groups folder, select the performance group you want.
- In the performance group pane, click Refresh.
