Configuring Auto Refresh
  1. Expand the Performance Manager slider and select Devices.
  2. In the Devices pane, navigate to the device group folder you want.
  3. Select a device in the device group folder and click View.
    The Performance Groups folder appears in the navigation pane with performance groups below it.
  4. Under the Performance Groups folder, select the performance group you want.
  5. In the performance group pane, click Auto refresh.
  6. In the Auto Refresh dialog box, enter the number of seconds you want to configure for the auto refresh of performance data from this device performance group.
  7. Click OK.
