Stopping Auto Refresh
  1. Expand the Performance Manager slider and select Devices.
  2. In the Devices pane, navigate to the device group folder you want.
  3. Select a device in the device group folder and click View.
    The Performance Groups folder appears in the navigation pane with performance groups below it.
  4. Under the Performance Groups folder, select the performance group you want.
  5. In the performance group pane, click Stop auto refresh.
    The automatic refresh function of performance data stops.
