Delete an Element from an Existing Reusable Configuration Module Expand the Configuration Manager slider, and select Configuration Tools > Reusable Modules. Select the RCM, and click Load. Select the element you want to delete from the Elements defined table, and click Delete. In the confirmation dialog, click OK.
