Update a Network Function Device Configuration
Pre-requisites: You must apply the RCM to a device before you can save and activate changes. See theApply an RCM to a Device section for more information.
- Expand the Configuration Manager slider, and select Devices.
- In the Managed Devices table, navigate the folder hierarchy to the network function (NF) device, and click Update.
In the update dialog, choose from the following options:
(Default) Select Save & activate configuration to save the configuration and make the current working configuration on the device the running configuration.
Select Save configuration to save the current working configuration changes to the device.
Select Activate configuration to make the current working configuration the running configuration.
