View Device Configuration Changes
- Expand the Configuration Manager slider, and click the Devices folder.
- In the Managed Devices table, expand the folder hierarchy, select a network function (NF) device, and click View Changes to display a list of all configuration changes made for this device.
In the
Configuration Changes pane, the changes made by the current user appear for the NF device in the
LCV (Local Configuration View) table. The following table describes the LCV columns:
Name Description User The name of the user who performed the configuration changes. Type The CLI parameter name. Name The configuration element instance name. Operation The result of the parameter change that occurred on the configuration. Valid values are created, modified, and deleted. Time changed The time when the configuration changed, which is not propagated yet to the device. -
You can use the following actions in the
Configuration Changes pane:
You must have the appropriate user privileges to perform actions in the Configuration Changes pane.Name Description Refresh Click to refresh the data in the view changes list. Undo Changes button Select a change row and click to undo selected changes. Change Owner Click to transfer the ownership of your changes to another user. Update Click to launch a dialog that is used to update the configuration with one of the following options: - (Default) Click Save & activate configuration to save the configuration and make the current configuration on the device the running configuration.
- Click Save configuration to save the current configuration changes to the device.
- Click
Activate configuration to make the current configuration the running configuration.
This option displays depending on the changes that were saved.
