Track Device Configuration Changes
Use this task to track changes that are made to device parameters.
- Expand the Configuration Manager slider, and click the Devices folder.
- In the Managed Devices table, expand the folder hierarchy, select a network function (NF) device, and click Get Inventory.
- In the Configuration inventory dialog that appears for the device, review the number of each type of configuration element.
- (Optional) Click Save to file.
- In the dialog that appears, click OK to download the information in the format of a comma-separated values (CSV) file to your system.
