Creating Network Interfaces
You must create a default network interface that is associated with your physical interface.
- Expand the Configuration Manager slider, and click Devices.
- In the Managed Devices pane, select a device, and click Load.
- In the navigation panel, click the Global Settings folder to expand the configuration navigation tree for the loaded device.
- In the navigation panel, click Interfaces.
In the
Interfaces pane, click
Add in the
Network interface table.
Click the arrow on the Guidelines box to view dependencies regarding your network interface. -
In the
Add Network interface dialog, complete the following fields:
Name Description VLAN number field If this network interface is not channelized, keep this port set to 0 (default). If this network interface is channelized, enter the appropriate VLAN number (sub-port ID). Physical interface drop-down list Click the physical interface to which this network interface corresponds in the drop-down list. - Click Apply.
In the
Success dialog, click
OK.
The newly-added network interface appears in the Network interface table.
