Configuring Network Interfaces
Use this task to configure your session delivery device to communicate with any network element.
- Expand the Configuration Manager slider, and click Devices.
- In the Managed Devices pane, select a device, and click Load.
- In the navigation panel, click the Global Settings folder to expand the configuration navigation tree for the loaded device.
- In the navigation panel, click Interfaces.
In the
Physical interface table, click an existing physical interface.
The network interface belonging to the selected physical interface appears in the Network interface table.
- Select this network interface, and click Edit.
The
Interfaces pane displays. In the
Host section complete the following fields to configure network interface parameters for the device:
Name Description Host name field The host name of this network interface. This field is populated with default. IP address field The IP address of this network interface. Subnet mask field The subnet mask of this network interface. Primary IP Address field The primary gateway that this network interface uses to communicate for the next hop route. Secondary IP Address field The secondary gateway of this network interface (if applicable). - To configure parameters that monitor the health of the gateway, click Add in the Gateway heartbeat section.
In the
Add Gateway heartbeat dialog, complete the following fields:
Name Description State drop-down list Select to enable or disable the gateway heartbeat feature. The default value is enabled. Expected ARP message interval from gateway (sec) field The number of seconds between heartbeats for the media interface gateway. Heartbeats are sent at this interval as long as the media interface is viable. The default value is 0. The valid range is from 1 to 65535.
The value you configure in this field overrides any globally applicable value set in the gateway heartbeat interval parameter in the device HA node (redundancy) configuration.
Number of ARP request retransmissions (#) field The number of heartbeat retries that you want sent to the media interface gateway before it is considered unreachable. The default value is 0. The valid range is from 1 to 65535.
ARP request timeout (sec) field The heartbeat retry time-out value in seconds. The default value is 1. The valid range is from 1 to 65535. This parameter sets the amount of time between device ARP requests to establish media interface gateway communication after a media interface gateway failure.
Health score decrement-gateway or link failure field The amount to subtract from the device health score if a media interface gateway heartbeat fails. If the value you set in the retry-time-out field is exceeded, this amount is subtracted from the overall health score of the system. The default value is 0. The valid range is from 0 to 100.
- Click Apply.
- To configure tunnel parameters for the device, click Add in the Tunnel config section.
In the
Add Tunnel config dialog, complete the following fields:
Name Description Name field The unique name for the IPsec tunnel configuration. Local IP address field The local public IP address that terminates the IPSec tunnel. Remote IP address field The remote public IP address that terminates the IPSec tunnel. - Click Apply.
In the
DNS section, complete the following fields to set a specific IP address for the network interface and others that are related to different types of management traffic:
Name Description Primary field The domain name server (DNS) server for this network interface. First backup field The secondary DNS server for this network interface (if applicable). Second backup field The third DNS server for this network interface (if applicable). Default domain name The default domain for use with DNS queries. DNS timeout The DNS timeout value. -
To configure (HIP) host-in-path firewall functions that are used to open well-known ports for services such as FTP, ICMP, SNMP, and Telnet over the media interfaces, complete the following fields:
Name Description HIP IP addresses box The IPv4 addresses of the front panel network interfaces that are allowed to pass administrative traffic to the host. Adding HIP entries automatically opens the well-known port associated with a service. FTP address field The FTP interface IP address. ICMP addresses box The ICMP interface IP address(es). SNMP address field The SNMP interface IP address. Telnet address field The Telnet interface IP address. SSH address field The SSH interface IP address. - Click Apply.
- In the Success dialog, click OK.
