Saving Net-Net SBC Configurations
During the save and activation process, other users cannot make changes to the device.
- Expand the Configuration Manager slider, and click Devices.
- In the Managed Devices pane, select a device, and click Load.
- In the Managed Devices panel, click the Home folder to expand the configuration navigation tree for the loaded device.
- Select the device, and click Update.
In the
Update configuration dialog, click one of the following update operations:
Save & activate configuration—(Default) Invokes the save and activate process
Save configuration—Invokes the save process.
Activate configuration—Makes this configuration the running configuration on the device.
- Click OK.
In the
Information dialog, click
OK.
The operation you selected appears in the Device tasks table.
- In the Device tasks table you can the operation row and click View log to get logging data for your device or save logging data to file on your local system.
