Search the Archive for a Configuration
Use this task to search for a configuration in the configure archive for an existing configuration backup.
The following search criteria can be used:
- Standard wild card
* and
? characters are supported.
- * matches 0 or more characters.
- ? matches 1 character.
- Search filters containing wild card characters must be enclosed in double quotes: “fo*”.
- Search filters containing no wild card characters result in an exact match.
Wild card characters cannot be used outside of double quotation marks in combination with an exact match search.
“A*1” is a valid search filter.
“A*”* is not a valid search filter.
