PreviousNextJavaScript must be enabled to correctly display this content
Executing an On-Demand Purge
You can select the purge policy you set earlier or target all backed up configurations on a device or group. You can select multiple devices or multiple groups to purge at one time.
On the
Configuration Manager slider, choose
Configure archive > Administration.
Click the
Operation tab and complete the following fields:
Name
Description
Configuration archive purge policy section
Choose the scope of the purge:
Purge all archived configuration—Choose to purge all files and configurations associated with selected device(s) or device group(s).
Purge per policy—Choose to purge selected devices according to set purge policy.
Select the NF folder or device that you want to purge from the
Managed devices table, and click
Add.
The NF folder or device appears in the
Targeted devices table.
Repeat the previous step to select more NF folders or devices that you want to purge.
