Create New Persistent Stores
JMS-related services require you to configure a custom persistent store that is also targeted to the same migratable targets as the JMS services. For the migratable solution, a file-based custom store is created, which points to the JMS Server to the same Migratable Target as the custom store.
- Log into the Administration Console.
- In the Domain Structure tree, expand Services, and then select Persistent Stores.
- Under Change Center, click on Lock & Edit.
- In the Summary of Persistent Stores table, click New, Create FileStore.
- Name the new file store and for the Target drop-down select bi_server1 (migratable).
- The Directory field must be a pathname that is accessible from every node that was declared a Candidate Server when modifying the bi_server1 (migratable) target. Whether you decide to use NFS, a storage area network (SAN), or a dual-ported SCSI disk, make sure this pathname set for the Directory exists and can be accessed from every Candidate Server node.
- Click Activate Changes under the Change Center.
