PreviousNextJavaScript must be enabled to correctly display this content
Configure a Migratable Target
When installing a BIP cluster, the system automatically generates
migratable targets of "<servername> (migratable)" for each running server
in the cluster.
In the
Change Center section of the pane, click
Lock &
Edit.
In the
Domain Structure section, click to expand the
Environment menu and
click
Migratable
Targets.
In the
Summary of Migratable Targets pane appears.
Select the
Migration tab.
Under
Constrained Candidate Servers, select the
servers you want to use as a JMS Server backup and move them to the
Chosen list. Check the the candidate server
check boxes in the
Available box and move them by clicking on the
right arrow to the
Chosen box.
Click
Save.
To activate these
changes, in the
Change Center of the administration console,
click
Activate
Changes.
If a message
says that some items must be restarted, then please restart the required
servers.
