Save and Transfer the BI Publisher Certificate to Session Delivery Manager
Open your web browser and connect to BI Publisher. For example:
You must use secure HTTPS.https://<myhostname>:7002/xmlpserver
- Confirm that you understand the risks.
- View and add the server certificate.
- Select the server certificate you that you added and click Export.
Save the file with the .cer extension in one of the following formats:
- X.509 PEM (Linux)
- Base-64 (Windows)
- Use the secure file transport protocol (SFTP) to send the saved BI Publisher certificate to a directory on your Oracle Communications Session Delivery Manager server.
